LocoNerdGeek Posted March 15, 2022 Share Posted March 15, 2022 Hi Is there any know how in existence how to make Dunlop DVP-5 work with Helix Effects? I'm on 3.15 firmware and expression pedal is all over the place. Considering to do factory reset and to start from scratch. One of the other things which confuses me is to what cable I should use to connect expression pedal with my HXFX. Manual states TRS, often recommendation on forums is either TS or TRS to TS Side note, both HXFX and DVP5 are new to me so it's quite possible I just don't know how to make them work together. Any tips welcome Alternatively can I have a schematic of expression pedal, please? I can always rewire mine Quote Link to comment Share on other sites More sharing options...
LocoNerdGeek Posted March 16, 2022 Author Share Posted March 16, 2022 Cancel it. I made it work after spending more time with HX edit Quote Link to comment Share on other sites More sharing options...
coachz Posted March 16, 2022 Share Posted March 16, 2022 I spoke with Dunlop on the phone because I have the same pedal and ended up using an insert cable with the TRS going into the helix and just one of the cables going into the pedal. Using just a TS cable I had intermittent problems so the insert cable was the good fix. That also leaves an extra TS connector for another pedal or switch. I had to press the blue button inside the DVP5. Quote Link to comment Share on other sites More sharing options...
LocoNerdGeek Posted March 16, 2022 Author Share Posted March 16, 2022 On 3/16/2022 at 12:15 PM, coachz said: I spoke with Dunlop on the phone because I have the same pedal and ended up using an insert cable with the TRS going into the helix and just one of the cables going into the pedal. Using just a TS cable I had intermittent problems so the insert cable was the good fix. That also leaves an extra TS connector for another pedal or switch. I had to press the blue button inside the DVP5. Yeah I pressed the polarity switch too. I did some of my presets today with one DVP for Volume and the other for functions (speed in modulations and such) and so far so good. I like this pedal a lot, sized perfectly for Metro pedaltrains and really well made so I hope it will keep working as I want it Quote Link to comment Share on other sites More sharing options...
coachz Posted March 16, 2022 Share Posted March 16, 2022 You might also take the volume block and set it up how you want and then right click and make it a user default. That way it adds nicely to any future presets Quote Link to comment Share on other sites More sharing options...
LocoNerdGeek Posted March 17, 2022 Author Share Posted March 17, 2022 On 3/16/2022 at 5:58 PM, coachz said: You might also take the volume block and set it up how you want and then right click and make it a user default. That way it adds nicely to any future presets Great tip, thank you Quote Link to comment Share on other sites More sharing options...
