Dweinin357 Posted March 20, 2022 Share Posted March 20, 2022 Hey everyone. Helix LT. I have a really simple signal chang. I'm running USB into my DAW logic. I can pan the guitar signal in logic left and right no problem.... but not with my helix. I have just 1 amp in my signal chain and a stereo modulation block. If I click on the output icon I get the options of pan and level. However if I pan everything left, the signal sounds centered and if I pan it right, it fades all the sound. What am I doing wrong? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
datacommando Posted March 20, 2022 Share Posted March 20, 2022 On 3/20/2022 at 5:44 AM, Dweinin357 said: I'm running USB into my DAW logic. Hi, On an almost daily basis since 2016, I have been using my Helix floor to record into Logic over USB and haven’t personally encountered this situation. I may be misunderstanding what you are asking, because if you have only a mono amp block followed by a stereo chorus, then you should not need to change anything on the hardware end. The USB channels 1 and 2 send the left and right audio into a stereo input channel in Logic (to be able to re-amp, I also take a clean DI in mono from USB 7) One thing springs to mind though - you do realise that pan knob on the channel strip in Logic defaults to a balance control, in order to make it work as a stereo pan knob you need to option click on it. Please clarify if I am misinterpreting the issue, for example - does this happen on every preset? We need to figure out if this is a setting on the LT or in Logic. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
Dweinin357 Posted March 20, 2022 Author Share Posted March 20, 2022 Ah. I did NOT know that you need to option click the pan knob to get it to work in Stereo. I'll give that a try later today when I get a minute and see what happens. Thanks for the tip. Quote Link to comment Share on other sites More sharing options...
datacommando Posted March 20, 2022 Share Posted March 20, 2022 On 3/20/2022 at 5:05 PM, Dweinin357 said: Ah. I did NOT know that you need to option click the pan knob to get it to work in Stereo. I'll give that a try later today when I get a minute and see what happens. Thanks for the tip. Hi, No - simply download the Helix Template for Logic that I linked in your other post about low levels in the DAW. And that "Option Click" should have read "Control Click" to bring up the true stereo pan in Logic. Let me know how it works with the template. 1 Quote Link to comment Share on other sites More sharing options...
Dweinin357 Posted March 21, 2022 Author Share Posted March 21, 2022 Ok. Your file worked like a charm. So I opened up a new clean file and that worked like a charm too. I opened up my old file and I think I needed to change my input again. It was set to input 1&2 but still not in stereo. I closed it down, reopened it, and it defaulted to input 1 only. So I changed it again to 1&2... and now it works in stereo like it should. Weird. Thanks for the help! Much appreciated. 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted March 21, 2022 Share Posted March 21, 2022 On 3/21/2022 at 5:24 AM, Dweinin357 said: and now it works in stereo like it should. Hi, Glad to hear that you have managed to blow out the bugs, and you’re up and running. Now you can enjoy recording with the LT - have fun. Quote Link to comment Share on other sites More sharing options...
