Catalyst FX loop - line or instrument level?
jeffboyer5
I use Helix Floor, not HXFX, so YMMV.
This is how I set it up in 4cm:
Guitar>HELIX IN (INST)>HELIX SEND (INST)>AMP IN >AMP SEND>HELIX RETURN (LINE)>HELIX OUT (LINE)>AMP RETURN
Reasoning: The amp's INPUT expects an Instrument. The Sends and Returns are LINE Level. The Output is going to a poweramp IN, therefore LINE.*
These are general rules of how amps work. The ACTUAL levels of various amps' FX Loops vary wildly. That (I believe) is why Helix/HXFX Loops have LEVEL controls because, bottom line, the difference between INST/MIC/LINE is simply db/voltage level of the signal, and it's all about GAIN STAGING. Being able to set the level to INST/MIC/LINE just gets you in the ballpark.
In order to get these level settings I use two Helix FX Loops because the SEND/RETURN can't be configured separately.
IOW - FX Loop 1 set to INST; FX Loop 2 set to LINE
If you're using the FX unit simply in the amp's FX Loop, one FX Loop Block set to LINE is sufficient.*
*If you've got guitar stompboxes anywhere in the signal chain, they expect an INSTRUMENT level signal.
