TheOneTrueRobb Posted May 5, 2022 Share Posted May 5, 2022 OK, a question: The Firehawk's pedal is a volume pedal by default. It controls the final output of the unit. However... I'd sure like to assign it to the input gain -the signal strength into the unit, pre-FX, so that when I back off the pedal, the gain into the Amp Sim is attenuated. Is there a way to do that? Thanks...! Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 5, 2022 Share Posted May 5, 2022 On 5/5/2022 at 10:49 AM, TheOneTrueRobb said: …… The Firehawk's pedal is a volume pedal by default. It controls the final output of the unit. ….. Actually it controls the level of the signal as it leaves the VOL block at its position in the signal chain. Using the Firehawk app you can drag the Vol pedal to place it at the beginning of the signal chain, or at least in front of the amp. Then it will behave the way you want. Quote Link to comment Share on other sites More sharing options...
