davetherrien Posted May 8, 2022 Share Posted May 8, 2022 Tap Tempo is MIDI CC 64 - not very useful... I'd like to see something where I set the tempo value in BPM as a MIDI value. That would be super useful. Hotone Ampero offers that and it really helps with setting the tempo for beat sync'd delays. Dave Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 9, 2022 Share Posted May 9, 2022 You mean MIDI clock sync? Or something else? Quote Link to comment Share on other sites More sharing options...
davetherrien Posted May 9, 2022 Author Share Posted May 9, 2022 I have no idea how to use the Catealyst "MIDI CC#64 - Tap Tempo - Each press simulates a Tape Tempo button press". Do I need to send out successive MIDI messages that are timed to a BPM? That's a lousy implementation. I have a Hotone Ampero and I can program it via MIDI to correlate to a BPM value - that's what I'm asking Line6 to implement... 1 Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 9, 2022 Share Posted May 9, 2022 On 5/9/2022 at 6:42 AM, davetherrien said: I have no idea how to use the Catealyst "MIDI CC#64 - Tap Tempo - Each press simulates a Tape Tempo button press". Do I need to send out successive MIDI messages that are timed to a BPM? That's a lousy implementation. I have a Hotone Ampero and I can program it via MIDI to correlate to a BPM value - that's what I'm asking Line6 to implement... The CC64 tap tempo is basically for creating a MIDI tap tempo switch. It’s a pretty common implementation for devices that use tap tempo. I’ve actually never seen an implementation like Hotone is using here. I suspect that MIDI clock might be added to the Catalyst at some point. I don’t think Line 6 would ever do anything like the Hotone implementation, though. That seems kind of confusing to me. Quote Link to comment Share on other sites More sharing options...
davetherrien Posted May 10, 2022 Author Share Posted May 10, 2022 hey @phil_m thanks for the response. PM value and then simulates a series of three tap tempo commands with the appropriate millisecond delay between them to get to a BPM value. This is valuable because I do a lot of songs that are delay sync'd to a BPM value. I use an ipad to send out the BPM value for the song and I know that the delay will be dead on to the rhythm. Hotone Ampero also has a basic drum machine which is driven from this BPM message. Does that make sense? Quote Link to comment Share on other sites More sharing options...
davetherrien Posted May 10, 2022 Author Share Posted May 10, 2022 I'd still like to see this functionality within the Catalyst MIDI implementation, but I just found out that, in the ipad ForScore application that send MIDI out to devices like the Catalyst, I can create a collection of MIDI presets at various popular BPMs that will issue two MIDI tape tempo commands separated by a delay time in milliseconds! So for 120 BPM, I'd send a Catalyst CC Tap tempo message, then a delay 500ms, then another Catalyst CC Tap Tempo message. I get my amp tomorrow, so I will test this out. Quote Link to comment Share on other sites More sharing options...
davetherrien Posted May 12, 2022 Author Share Posted May 12, 2022 (edited) I tried to program a sequence of MIDI tap tempos separated by millisecondS of delay, but this produced very variable and unpredictable BPM values - the range of BPM was too great for this to be a good solution. I'm running this on an ipad and the MIDI Delay latency must be too variable. So I ask again if this is BPM setting code that can live inside the Catalyst and be executed more accurately by me sending two CC messages that are encoded as a BPM value as Hotone has done in their Ampero. (see previous diagram) I do a lot of rhythmic delay playing to 1/8 and DOTTED 1/8 notes, so this is a feature request that I'd really like to see implemented. For now, I guess I'll have to use the tap tempo button on the LFS2 footswitch. Not great since I have the Hotone stuff completely automated and this would be a manual step during a performance. Edited May 12, 2022 by davetherrien MISTAKE IN TEXT Quote Link to comment Share on other sites More sharing options...
soundog Posted May 13, 2022 Share Posted May 13, 2022 The best thing would be to request support for MIDI clock, or Ableton Link. I think the original MIDI spec dropped the ball a bit with the lack of a CC for setting a tempo (hence workarounds like Ampero), but that's water under the bridge. If you have a clever app (like Set List Maker) you can set it up so that a tap tempo CC command is sent on quarter note downbeats in sync with MIDI clock. I use that feature with an HX Stomp all the time; I send the first four beats to set tempo for time-based effects. 1 Quote Link to comment Share on other sites More sharing options...
