clivea Posted May 27, 2022 Share Posted May 27, 2022 Hi guys, I have just bought a 112 Plus to use with my Kemper Rack Mount and I'm unsure how to lead them up together. I shall mainly use the gear for recording through my DAW on W10. Also, how should the Global be set? Any set up advice would be appreciated. Thanks in advance. Clive Quote Link to comment Share on other sites More sharing options...
bobcoss Posted June 3, 2022 Share Posted June 3, 2022 No responses probably because like most here we don't know much about the Kemper. If you are recording through a DAW and you don't have a separate interface or the Kemper doesn't record via the USB out, then you can hook your Kemper line out directly to the PC+. Run as high of a signal from the Kemper as you can for the best signal to noise ratio. I suspect that the input levels for the PC+ USB interface are going to be dependent on the level coming into the PC+. I have never recorded from my PC+ so I am not sure. By all reports, the inteface will be very good. Quote Link to comment Share on other sites More sharing options...
vannamalay Posted January 17, 2023 Share Posted January 17, 2023 Just noticed this topic. I have a Kemper Stage as well as the Helix LT. Was going to buy a Power Kabinet. I have started to use the PC+ 112 and it works great. In the Output section of the Kemper - p9, the Kone settings can be adjusted and do impact on the Powercab. Quote Link to comment Share on other sites More sharing options...
