Jesusrocker Posted June 13, 2022 Share Posted June 13, 2022 New Helix owner and trying to get comfy with programming...Downloaded a patch from another user and am trying to add a block for an IR after the speaker cab, but the path is completely full. What's the trick to get some room for another block? Do I maybe split the path, add the block and then merge? That's not intuitive to me. TIA. Quote Link to comment Share on other sites More sharing options...
datacommando Posted June 13, 2022 Share Posted June 13, 2022 On 6/13/2022 at 6:05 PM, Jesusrocker said: What's the trick to get some room for another block? Do I maybe split the path, add the block and then merge? That's not intuitive to me. TIA. Hi, No tricks. The simple solution, and the answer that most people don’t like to hear is - consult the manual - it is your friend. Helix 3.0 Owner’s Manual - Rev F - English - Page 20 Moving Split & Merge Blocks for More Parallel Routings https://line6.com/data/6/0a020a3f041b611d61cac763b/application/pdf/Helix 3.0 Owner's Manual - Rev F - English .pdf if reading is not your thing - try a video. Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
