jamme61 Posted June 18, 2022 Share Posted June 18, 2022 Foot switch B will not assign to drive pedal Minotaur? I touch the footswitch and nothing happens - if I touch the other footswitches it works? Its only this drive pedal with footswitch B? I tried going to a different patch and same thing - also unplugged unit and powered up again and same thing - thanks for any help very new the HX stomp XL Quote Link to comment Share on other sites More sharing options...
datacommando Posted June 19, 2022 Share Posted June 19, 2022 On 6/18/2022 at 3:54 PM, jamme61 said: Foot switch B will not assign to drive pedal Minotaur? I touch the footswitch and nothing happens - if I touch the other footswitches it works? Its only this drive pedal with footswitch B? I tried going to a different patch and same thing - also unplugged unit and powered up again and same thing - thanks for any help very new the HX stomp XL Hi, You haven’t really given much to go on with this. Does this only happens with the Minotaur drive, or does it occur with any/or all effects assigned to FS B specifically? You say that you changed presets and this still happens. Once more is this only with the Minotaur, or all effects? When weird stuff starts to happen- perform a factory reset, or run the rebuild presets routine to see if it blows the bugs out. Information on this here: Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
