makeegan Posted June 26, 2022 Share Posted June 26, 2022 Hi I updated firmware and HX Edit to 3.15. There are no presets. One mic model (Studio) The new Line 6 amp Ventoux is in there. Am I missing something? Cheers and thnx in advance Quote Link to comment Share on other sites More sharing options...
datacommando Posted June 27, 2022 Share Posted June 27, 2022 On 6/26/2022 at 11:41 PM, makeegan said: Am I missing something? Yep! it’s right there in the Release Notes. I updated but why don't I see [Model X]? HX Edit can't magically see new models added to your Helix/HX hardware; you must update HX Edit as well (which you would've done had you followed "How do I update to 3.15?" above). Here's a link to HX Edit 3.15: macOS: https://line6.com/software/readeula.html?rid=11009 Windows: https://line6.com/software/readeula.html?rid=11007 Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
makeegan Posted June 28, 2022 Author Share Posted June 28, 2022 Thanks for the reply. I followed the update procedure and release notes and I have 3.15 HX Stomp and 3.15 HX Edit. I was expecting the preset list to be populated with factory examples and the mics to correspond to the documentation My version doesn't-see attached. Thanks Quote Link to comment Share on other sites More sharing options...
datacommando Posted June 28, 2022 Share Posted June 28, 2022 On 6/29/2022 at 12:07 AM, makeegan said: Thanks for the reply. I followed the update procedure and release notes and I have 3.15 HX Stomp and 3.15 HX Edit. I was expecting the preset list to be populated with factory examples and the mics to correspond to the documentation My version doesn't-see attached. Thanks Hi, again, If you followed the notes about updating to v.3.15, you would have made a backup of your Stomp before performing the update. When the update was complete you would also have followed these instructions from the notes: Anything else I should know? Yes. We STRONGLY recommend performing a factory reset AFTER UPDATING your Helix/HX firmware to 3.15 and THEN RESTORING YOUR BACKUP. (Backing up is part of the update process). Here's how to perform a factory reset. IMPORTANT: MAKE SURE YOU HAVE A BACKUP FIRST, AS A FACTORY RESET WILL ERASE ALL YOUR WORK! If you didn’t do a reset - here are your options. HX Stomp Button Combination Description All 3 Footswitches Clears all presets/IRs FS1+2 Resets presets and IRs FS 2+3 Factory restore (globals, presets, IRs To use Reset Options: Power off the Helix Hold the desired button combination Power on the Helix Release the button combination I’m also not too sure about your reference to “Mics”. There is only one Studio Microphone Preamp available (as shown in your screen shot). If you select an amp/speaker combination, or as separate components, you can then select what type of microphone is used with the speaker cabinet, and at what distance it is (virtually) placed from the speaker grille. There are lots of model choices and types - for example: dynamic, condenser and ribbon. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
