zeisse Posted June 28, 2022 Share Posted June 28, 2022 Hi, I just bought used JTV 59. The guitar is in perfect condition, everything works fine but there is a regular click about every second while using magnetic pickups. The click is audible only if battery is assembled. Without battery click is gone. Any idea what is going on? Thanks Quote Link to comment Share on other sites More sharing options...
psarkissian Posted June 28, 2022 Share Posted June 28, 2022 Active circuit is engaged. Use a 1/4" TRS (tip/ring/sleeve) plug cable. Quote Link to comment Share on other sites More sharing options...
zeisse Posted June 28, 2022 Author Share Posted June 28, 2022 On 6/28/2022 at 6:16 PM, psarkissian said: Active circuit is engaged. Use a 1/4" TRS (tip/ring/sleeve) plug cable. I've just checked it with stereo cable (the one I have for variax acoustic) and the click is still audible. Quote Link to comment Share on other sites More sharing options...
zeisse Posted June 28, 2022 Author Share Posted June 28, 2022 click.avi I made short video to show the click. You can hear buzz noise which is less audible when volume potentiometer is turning down but the click is present almost till potentiometer is fully closed. https://youtu.be/IdijLMPXA6Y Quote Link to comment Share on other sites More sharing options...
psarkissian Posted June 28, 2022 Share Posted June 28, 2022 That clicking is switch on the main board. There's is a problem with the 1/4" TRS jack circuit, and the main board may also be affected. It will need to be serviced by a Line 6 authorized technician in your area. https://line6.com/find/service_center/ Quote Link to comment Share on other sites More sharing options...
zeisse Posted June 29, 2022 Author Share Posted June 29, 2022 I've contacted local autorized services and waiting for feedback. Hope it will be simple to fix. Thanks Quote Link to comment Share on other sites More sharing options...
