kert46 Posted July 20, 2022 Share Posted July 20, 2022 It is an ir that is being used by Helix, but it cannot be imported from Helix Native. What should I do? The program I am using is Logic Pro x. plz help Quote Link to comment Share on other sites More sharing options...
phil_m Posted July 20, 2022 Share Posted July 20, 2022 You need to be signed into your Line 6 account in HX Edit in order to import those. The .hir files are DRM protected and are tied to your account. As long as your Helix is registered to the same account that Native is licensed to, they should work. 1 Quote Link to comment Share on other sites More sharing options...
kert46 Posted July 21, 2022 Author Share Posted July 21, 2022 On 2022. 7. 21. at 오전 1시 33분, phil_m said: 이를 가져오려면 HX Edit에서 Line 6 계정에 로그인해야 합니다. .hir 파일은 DRM으로 보호되며 귀하의 계정에 연결됩니다. 귀하의 Helix가 Native 라이선스와 동일한 계정에 등록되어 있는 한 작동해야 합니다. Thank you for answer. However, it is executable because you are already logged in to run Helix Native. If so, should I install and run HX edit and then run Helix Native? Quote Link to comment Share on other sites More sharing options...
kert46 Posted July 21, 2022 Author Share Posted July 21, 2022 I logged in with hx edit and Helix Native in the same way. In hx edit it gets IR fine. The problem is that I still can't get IR from Helix Native. help Quote Link to comment Share on other sites More sharing options...
