kmcnall Posted July 20, 2022 Share Posted July 20, 2022 Hello! I struggled mightily with this problem, so I want to document it on a clean thread. I'm grateful for those whio helped and tried to help with this issue. Problem: After migration to a new Mac Studio using Migration Assistant, Helix Native crashed my DAW hard with any access of the Helix Native Plugin. Attempting to load any project already using the plugin also crashed immediately. Ultimate Reason for Crash: Helix Native's authorization process is not friendly to the Migration Assistant. There does not seem to be a clean process for migrating to a new Mac. I'm still unclear on exactly what happened and why. Ultimate Solution: Completely uninstalling and reinstalling Helix Native. There is not a clean way provided to do this. The following information was provided by Line6 on what needs to be removed to completely uninstall Native and whatever data file was the actual culprit. Please use due caution before using this procedure: Please look for and delete the following files: /Library/Application Support/Avid/Audio/Plug-Ins/Line 6/Helix Native.aaxplugin /Library/Audio/Plug-Ins/Components/Helix Native.component /Library/Audio/Plug-Ins/VST/Line 6/Helix Native.vst /Library/Audio/Plug-Ins/VST3/Line 6/Helix Native.vst3 Delete the following folders: Folder 1: /Library/Application Support/Line 6/Helix Native/ Folder 2: ~/Library/Application Support/Line 6/Helix Native/ - this folder is hidden by default. In Finder, from "Home" view, press Command/Shift/and Period to display the ~/Library folder. It will appear grayed out but able to navigate within it. Once completed, download and install the latest version of Helix Native. When you relaunch your DAW and access the Helix Native plugin, you may ore may not be prompted to log in and authorize. +++++++++ Many tried to help me with this. The tendency was to think my DAW (Digital Performer) was the culprit, so I installed Reaper and also tried to use Garage Band all with the same results. If Line6 was still providing telephone support, this would have been resolved much faster. Ticket support with 3-day turnarounds is tough. I've made the following recommendations to Line56 to hopefully spare others this problem. 1) If Helix Native is not friendly to Migration Assistant, let users know this, and provide a working procedure. 2) Provide a complete uninstall program, with a means to save user data. 3). Change the authorization process to avoid this problem. In the process of trying to resolve this, I did not run into a lot of people having this problem. I don't know why they would NOT have the problem if migrating from one Mac to another, unless their strategy was to simply reinstall everything. It may be that this occurrence was an anomaly unrelated to the normal process. I hope this might spare someone else the time and trouble.! Berst to all. 2 1 2 Quote Link to comment Share on other sites More sharing options...
crl713 Posted August 27, 2022 Share Posted August 27, 2022 Thanks for this. Having the same problem after Migration Assistant. Native is too good not to have a comprehensive uninstall. Quote Link to comment Share on other sites More sharing options...
chrissuddes Posted November 1, 2022 Share Posted November 1, 2022 Thanks for this. Worked for me, many thanks indeed for sharing MacBook Pro M1, Monterey 12.6.1 Quote Link to comment Share on other sites More sharing options...
PierM Posted December 16, 2023 Share Posted December 16, 2023 On 7/20/2022 at 9:07 PM, kmcnall said: Hello! I struggled mightily with this problem, so I want to document it on a clean thread. I'm grateful for those whio helped and tried to help with this issue. Problem: After migration to a new Mac Studio using Migration Assistant, Helix Native crashed my DAW hard with any access of the Helix Native Plugin. Attempting to load any project already using the plugin also crashed immediately. Ultimate Reason for Crash: Helix Native's authorization process is not friendly to the Migration Assistant. There does not seem to be a clean process for migrating to a new Mac. I'm still unclear on exactly what happened and why. Ultimate Solution: Completely uninstalling and reinstalling Helix Native. There is not a clean way provided to do this. The following information was provided by Line6 on what needs to be removed to completely uninstall Native and whatever data file was the actual culprit. Please use due caution before using this procedure: Please look for and delete the following files: /Library/Application Support/Avid/Audio/Plug-Ins/Line 6/Helix Native.aaxplugin /Library/Audio/Plug-Ins/Components/Helix Native.component /Library/Audio/Plug-Ins/VST/Line 6/Helix Native.vst /Library/Audio/Plug-Ins/VST3/Line 6/Helix Native.vst3 Delete the following folders: Folder 1: /Library/Application Support/Line 6/Helix Native/ Folder 2: ~/Library/Application Support/Line 6/Helix Native/ - this folder is hidden by default. In Finder, from "Home" view, press Command/Shift/and Period to display the ~/Library folder. It will appear grayed out but able to navigate within it. Once completed, download and install the latest version of Helix Native. When you relaunch your DAW and access the Helix Native plugin, you may ore may not be prompted to log in and authorize. +++++++++ Many tried to help me with this. The tendency was to think my DAW (Digital Performer) was the culprit, so I installed Reaper and also tried to use Garage Band all with the same results. If Line6 was still providing telephone support, this would have been resolved much faster. Ticket support with 3-day turnarounds is tough. I've made the following recommendations to Line56 to hopefully spare others this problem. 1) If Helix Native is not friendly to Migration Assistant, let users know this, and provide a working procedure. 2) Provide a complete uninstall program, with a means to save user data. 3). Change the authorization process to avoid this problem. In the process of trying to resolve this, I did not run into a lot of people having this problem. I don't know why they would NOT have the problem if migrating from one Mac to another, unless their strategy was to simply reinstall everything. It may be that this occurrence was an anomaly unrelated to the normal process. I hope this might spare someone else the time and trouble.! Berst to all. Man, I have to thank you for this! Lost 3 hours of my day because of that lollipop L6 authorization issue. I didnt do absolutely anything, just started with the DSP error out of the blue after a reboot, and none of the various suggestions around here worked out. Was going to give up 'til I've found this guide which worked perfectly. The core point here, at least for me, was to delete the two Application Support folders and reinstall. Thanks again, and another big BOOOO for L6. Just hire better coders, jesus christ. I have a huge library of plugins from any kind of developer, and Native is the only one giving me these random problems (lost the count of how many DSP erros I've got since I use Native, and every time it's a different voodoo to solve it) 1 Quote Link to comment Share on other sites More sharing options...
gastric Posted July 21, 2024 Share Posted July 21, 2024 Add another user you just saved after a similar experience. - Migrated from an older Intel Macbook to a M3 Macbook - Used Migration Assistant to move everything over - Reinstalled apps identified as Intel vs Universal/iOS which included all Line6 apps - Authorized my new computer with Line6 License Manager - Might have managed to login to my Line6 account in Helix Native (can't say for sure) - Reaper would immediately crash after that point anytime I opened Helix Native Was mildly annoying but wasn't terribly difficult thanks to your post. I was unable to find any official Line6 instructions on how to do this. I obviously lost my user data along the way. However, I still have the old Macbook I can create a backup. - On old Macbook: Settings > Presets/IR > Export Bundle - On new Macbook: Settings > Presets/IR > Import Bundle And discover my Presets have been imported but none of my IR or Favorites..... Onto my next adventure of exporting > importing all of those manually. And there's no Command+A support to select all, and I didn't name all of my damn IR with the slot name they were saved in so it's a huge PITA getting them all back into the correct place so they map with presets (I vaguely recall that's how they work). My minor annoyances are growing.... Quote Link to comment Share on other sites More sharing options...
