MikeBX3 Posted July 29, 2022 Share Posted July 29, 2022 I'm pretty new to the Helix and struggling with one or two things so I thought I'd post one of them here in the hope that someone can help me understand what's going on! I've seen youtube videos of Helix Edit where delay devices (e.g. Adriatic) feature a "Scale" slider. It appears that the slider is common to stereo delays When I select, say, the Adriatic delay there is no such slider. The entry for Adriatic shows it as being Mono/Stereo so I assume that in some way or other, my Adriatic is set to Mono. I can't see any way to switch it to Stereo though. Maybe I'm barking up the wrong tree though. Maybe I'm just barking mad! Can anyone explain why this might be and if possible how I can get the slider? TIA, MikeB Quote Link to comment Share on other sites More sharing options...
phil_m Posted July 29, 2022 Share Posted July 29, 2022 Only the stereo versions of the delays have the Scale parameter. You have to select the stereo version by going into the stereo menu first and then selecting the block there. It’s not like mono/stereo is a setting within the effect. The mono and stereo versions are completely separate blocks. Quote Link to comment Share on other sites More sharing options...
MikeBX3 Posted July 30, 2022 Author Share Posted July 30, 2022 On 7/29/2022 at 9:52 PM, phil_m said: Only the stereo versions of the delays have the Scale parameter. You have to select the stereo version by going into the stereo menu first and then selecting the block there. It’s not like mono/stereo is a setting within the effect. The mono and stereo versions are completely separate blocks. Excellent! I hadn't spotted the menu at the top of the category/model window. Thanks for that Phil Quote Link to comment Share on other sites More sharing options...
