stevenah Posted August 9, 2022 Share Posted August 9, 2022 I'm trying to use my Catalyst as an audio interface to use on my DAW. I've got the USB output connected to my computer. In my preferences on my DAW, I don't see the Catalyst as an option for input and output. Help. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted August 9, 2022 Share Posted August 9, 2022 You need to DL and install the ASIO Drivers: Line 6 1 Quote Link to comment Share on other sites More sharing options...
mateuszwojtyra Posted August 23, 2022 Share Posted August 23, 2022 Can I use only dry signal and play using helix native sounds in my DAW? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted August 24, 2022 Share Posted August 24, 2022 The Cat's ASIO sends both a wet and a dry signal. Check the PodGo manual to find out which USB channel is dry and use that. I suspect though that the RT Latency using this method might be excessive, but I haven't tried it so I may be wrong about that. Quote Link to comment Share on other sites More sharing options...
