Poodie2814 Posted August 10, 2022 Share Posted August 10, 2022 Does anyone know the output level of the amp out connection on the pod go and if it's switchable between line and instrument level like the main outs? Thanks! Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 10, 2022 Share Posted August 10, 2022 From the manual: AMP OUT This unbalanced output is meant to send directly to the front of your guitar amp. By default, it reflects the same output as the MAIN outputs (except in mono), but it can be globally switched to be tapped off directly before the Cab/ IR block. This way, you can send a cab-emulated signal to your mixer (or FRFR speaker) while simultaneously sending a non-cab-emulated signal to your guitar amp. So instrument level output, not switchable. 1 1 Quote Link to comment Share on other sites More sharing options...
Poodie2814 Posted August 10, 2022 Author Share Posted August 10, 2022 Yeah, I thought that would be the case. Thank you! Quote Link to comment Share on other sites More sharing options...
