pcurry83 Posted August 16, 2022 Share Posted August 16, 2022 So I've already found that you cannot dump previously dumped saved sysex presets back IN to the M5, nothing happens. Yes, I've tried everything, I know the process Mostly works because I had no problem dumping presets to my computer, it's just going back that doesn't work which renders the entire sysex dumping process meaningless Now I've just discovered that if you try to copy a preset from one slot to another, it doesn't copy the name you gave to the preset!!!! What a mess!!!!!! Managing presets on the M5 is therefore a total disaster. I'm wasting an entire day copying and renaming presets manually, having to play ping pong with an empty slot, and renaming every preset I copy through the tedious naming process, because the Sysex dump doesn't work. Quote Link to comment Share on other sites More sharing options...
