karakartal Posted August 17, 2022 Share Posted August 17, 2022 Hello everyone, Very soon my gigs are starting soon and I will be using the HX Stomp XL in these concerts. Our style is classic heavy metal and I want to use the device in the most effective way. What I want to do is... As I connect the device directly to the PA system, I also want to connect an output to the amp's return. I need to put a cabin simulator for the PA line. I'm not supposed to use a cabinet simulator for the signal going to the amp. When using the Helix LT, I was handling this by putting a cabinet on the XLR output path. The HX Stomp XL has no XLR output. I would be very appreciated if you could write/tell how I should do this. Thanks in advance... Quote Link to comment Share on other sites More sharing options...
rd2rk Posted August 17, 2022 Share Posted August 17, 2022 Attached example preset. L/Mono Out to amp return. Left send (TIP) to DI to FOH. You put the IR in the path, pull it down to split the paths, then pull down the MERGE block to split the outputs. karakartal.hlx 2 Quote Link to comment Share on other sites More sharing options...
karakartal Posted August 17, 2022 Author Share Posted August 17, 2022 On 8/17/2022 at 10:00 AM, rd2rk said: Attached example preset. L/Mono Out to amp return. Left send (TIP) to DI to FOH. You put the IR in the path, pull it down to split the paths, then pull down the MERGE block to split the outputs. karakartal.hlx 6.95 kB · 0 downloads Thank you very much. Quote Link to comment Share on other sites More sharing options...
