Helix Stomp Parallel Path with External Pedals to Stereo Out
straker101
I’m a newb to the Helix world so apologies if this is a simple answer or can be found elsewhere.
I run a dual amp stereo rig and wondering if I can incorporate the Helix Stomp to achieve the following:
I want to run my mono guitar signal into the Stomp then have two different analog dirt pedals on two separate loops. I want the ability with the tap of a switch to activate both dirt pedals simultaneously. Each dirt pedal would then go into a parallel chain in the Stomp and each chain would be assigned to a left and right output running each to a different amp. Key here is to be able to maintain the parallel chain while also being able to activate and cut both dirt pedals simultaneously.
