madhorizons Posted October 23, 2022 Share Posted October 23, 2022 I have a FBV3 that works fine on my Spider Valves and mostly working on the Pod HD Pro. For whatever reason, I cannot get the volume/wah pedal functional with the PHDP. I can unplug the FBV3 and put in a FBV Express MKII on the same cable and that works fine. I've updated the firmware. Thoughts? Quote Link to comment Share on other sites More sharing options...
Elenaclark Posted February 7 Share Posted February 7 I just want to say that It's possible that the issue with the FBV3 not working with the Pod HD Pro is related to compatibility or a software conflict. Here are some steps you can try to resolve the issue: 1. Check the compatibility: Make sure that the FBV3 is compatible with the Pod HD Pro and check the Line 6 website for any firmware updates or compatibility notes. Reset the Pod HD Pro: Try resetting the Pod HD Pro to its factory settings to see if that resolves the issue. 2. Check the connections: Ensure that the cable connections are secure and free from damage. Try a different cable to rule out a cable issue. 3. Try a different USB port: If the FBV3 is connected to the Pod HD Pro via USB, try connecting it to a different USB port on your computer. 4.Contact Line 6 support: If the issue persists, reach out to Line 6 support for further assistance. They may be able to help you resolve the issue or suggest a solution. If none of these steps work, it may be necessary to return the FBV3 for repair or replacement. DinarGuru Quote Link to comment Share on other sites More sharing options...
Hellandfrt Posted March 13 Share Posted March 13 That is what I was looking for, what information, present here at this site. Allied Universal eHub Website Quote Link to comment Share on other sites More sharing options...
