HX STOMP Multi OUT
As a bassist I don't need stereo OUT.
I'd really like the opportunity to split outs; When I play On big stages I'd like to have cab sim on a channel to send to Mixer and the other one to my amp. Now I have to do this turnaurund but it's a waste of blocks for me. Please Line 6, listen to Mono Bass Players too!Schermata-2022-10-30-alle-11-12-40.png
  • 1 month later...
Cesarelik,
Welcome to the forum.
An FYI, you should be posting this under Multi-Effects Units/Helix. You'll get a better response posting it there. Dream Rig has to do with Line 6 integration of the Variax guitars, Helix or POD HD with L6-Link, and Amps with L6-Link such as PowerCab, DT series amp or StageSource speakers. Just trying to help.
Jd
  • 2 years later...
Hi, I'm also new to this forum and need to check the channel that JakeMan19 mentioned. But in this channel this thread was quit on-top without solution.
But the solution seems simple to me:
We as bass players usually don't need stereo. Therefore you can safe this "send" block and use e.g. Main-Out-L for "Direct Out" and Lain-Out-R for "Processed Out" and send one to Amp and one to DI.
What I mean: The "junction" can be selected separately. You can there route all from the top signal path to "hard-left" and all from the extra signal path to "hard-raight". Then you can send e.g. with processing (Cab-Sim, Amps, whatever) to FOH and the other path to your Amp (e.g. other EQ, ...).
Hope-that-helps
best regards
Stefan
