HX Effects Pedal Order
pbatts
I couldn't find a like question or answer so here goes. This is specific to HX Effects.
I have seven effects blocks in use, including an effects loop and two overdrives. In stomp view I can see the effects loop and one overdrive. If I hold the Mode switch down to see “More", I can see the other OD on the second page.
How do I swap or move the FX Loop to the second page and the OD to the first page?
On 11/4/2022 at 3:07 PM, C4TH said:
if you want to see the OD on the first page, make sure your OD is assigned to a foot switch. If you want your FX Loop on the second page, make sure its *not*
assigned to a foot switch (none).
Perfect. Thanks.
It would be cool if there was a way to page over to engage or bypass effects that don't appear on the first page? Would anyone find that useful? Does anyone know if that idea is already on Ideascale?
Thanks again.
