denqxotl Posted November 14, 2022 Share Posted November 14, 2022 Hi there! Got a problem with my Helix LT. I turned it on and play for 20 mins, left it for a while turned on and when I got back to it, it stopped work. I can see a black screen and pedal indicators light. Tried to restart it. Same stuff. Checked my house power. It's ok, 220V. Few days ago made an update to 3.50. Everything was perfect. Tried to run test mode and factory reset -- nothing happens Any ideas, recommendations, etc? Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted November 16, 2022 Share Posted November 16, 2022 Defenitely something to contact Line 6 support. Quote Link to comment Share on other sites More sharing options...
sadova71 Posted April 2, 2024 Share Posted April 2, 2024 On 14/11/2022 at 19:31, denqxotl said: ¡Hola! Tengo un problema con mi Helix LT. Lo encendí y jugué durante 20 minutos, lo dejé encendido un rato y cuando volví a encenderlo, dejó de funcionar. Puedo ver una pantalla negra y una luz indicadora de pedal. Intenté reiniciarlo. Lo mismo. Comprobé la energía de mi casa. Está bien, 220V. Hace unos días se actualizó a 3.50. Todo era perfecto. Intenté ejecutar el modo de prueba y restablecer los valores de fábrica; no sucede nada. ¿Alguna idea, recomendación, etc.? hello! I have the same problem, helix lt has a black screen and both lights are on. Were you able to fix the Helx, did they tell you what the fault was? Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 2, 2024 Share Posted April 2, 2024 On 4/2/2024 at 8:55 AM, sadova71 said: hello! I have the same problem, helix lt has a black screen and both lights are on. Were you able to fix the Helx, did they tell you what the fault was? Hi, The blank screen would seem to indicate a problem with the power supply. The best thing you can do is contact Customer Support to see if they can help. Hola, La pantalla en blanco parecería indicar un problema con la fuente de alimentación. Lo mejor que puedes hacer es contactar con Atención al Cliente para ver si pueden ayudarte. Quote Link to comment Share on other sites More sharing options...
