HX Stomp - 4CM + IEM with IRs
lavida123
Hi!
I'm currently using the HX Stomp with my EVH 5150 with the 4 cables method. I did the setup of the 4CM using the Line 6 HX Stomp manual. Now, I want to include in the setup my in-ear monitor that I recently purchased. The problem is that I don' know if it is possible to configure the HX Stomp to use the 4CM using the 5150 with a real cab without any IR and, at the same time, use my in-ear monitors with an impulse response. Is this configuration possible?
Thank you!
Instead of using the 1/4" Main out for the 5150, add a SEND (If you're using FX Loop L for 4cm, use Send R.
You'll need a 1/4" Male TRS to dual 1/4" Female Mono INSERT cable. RING is Send R).
That completes the 4cm configuration.
Make sure that THRU is set to 0db in that SEND Block, then add your IR after that.
That'll get your IR at the HP and MAIN Outs.
