HectorSan Posted February 1, 2023 Share Posted February 1, 2023 Hi! I'm a new owner of the HX Stomp XL, so forgive me if the solution is obvious. I'm trying to integrate my HX Stomp with my pedals by using the Send and Return, however, mixed with my pedals signal is the dry signal from the HX. I need only the signal from the pedals. How can I set it up so that the only signal after the Send and Return block is from the L/Mono Return input? The routing is: Guitar into L/Mono Input, a cable going out of the Send into my pedals, a cable into L/Mono Return and two cables going out from Left and Right Output. All cables are mono Quote Link to comment Share on other sites More sharing options...
rd2rk Posted February 1, 2023 Share Posted February 1, 2023 Use a single FX Loop Block with the MIX set at 100% (default). If for some reason you choose to use separate SEND and RETURN Blocks, be sure to set the DRY THRU on the SEND Block to -120db (OFF). If you think that you're already doing this, attach a copy of your preset (NOT a screenshot!) so we can look at it. Quote Link to comment Share on other sites More sharing options...
