H3R3T1K Posted February 4, 2023 Share Posted February 4, 2023 I really wanna try this. Usually a LA Studio Comp gets used but I don't have the DSP left for that. I can only do the 3-Band Comp or the Deluxe. The context is distorted metal bass. Placed after IR last in chain. Can those 2 do the same as the LA Studio Comp in this context and what settings should I try? I'm no pro with regards to compression or recording and copied the settings for the Deluxe that I'm running on top of the low end portion of my signal from the internet. Quote Link to comment Share on other sites More sharing options...
datacommando Posted February 4, 2023 Share Posted February 4, 2023 On 2/4/2023 at 1:09 PM, H3R3T1K said: I really wanna try this Well, do it! What harm will it do? It's compression, it makes quiet things louder and loud things quieter. Doing it for yourself is the only way to learn. The Deluxe Comp is similar to studio compressors like the LA Studio Comp with lots of different ratios to try out, from 2:1 right up to 20:1 The 3 Band Comp, which as the name suggests splits the input into 3 signal bands Hi, Mid, Low and each can be compressed differently. It's similar to having a compressor with 3 EQ settings, so it should be fine with your Bass. You might want to consider buying "The Big Book of Helix Tips & Tricks" by Craig Anderton who contributes to this forum. It covers most stuff you might need to know about using the Helix products to it's best. An updated version is nearing completion so anyone who has already bought a copy will be able to update free. Get it here: https://www.sweetwater.com/store/detail/AndertonHX-e--sweetwater-publishing-the-big-book-of-helix-tips-and-tricks Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
