Stathis_SsS Posted February 4, 2023 Share Posted February 4, 2023 i don’t have any pedal.when I press the loop button and play something, then I press it again to play it in a repeating loop. my problem is that when this track that I have recorded stops, to start playing again, there is a delay of 3-4 seconds. how can I solve it without having this delay and what I have played is repeated directly? Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 4, 2023 Share Posted February 4, 2023 It’s possible that you recorded the ‘delay’. The Looper starts recording as soon as you tap the Start switch. It continues to record (including any silence) until you hit the Stop or Overdub switch. If there was any pause in starting to play after starting the looper, or before stopping it, that will be recorded as silence. You will hear the silence being played back. To get rid of it you will have to record the loop again, this time with no silent periods. Quote Link to comment Share on other sites More sharing options...
Jermainekieffer Posted February 23, 2023 Share Posted February 23, 2023 I am not an expert but I want to say you are experiencing a delay in the loop when you stop and start playing again. This could be due to a number of factors, including the processing power of your device, the size of the audio file, or the settings in your loop software. Here are a few things you can try to reduce the delay: Reduce the size of the audio file: If your audio file is large, it may take longer for your device to process the loop. Try reducing the length of the audio file or converting it to a lower quality format to see if this reduces the delay. Adjust loop settings: Some loop software may have settings that can be adjusted to reduce the delay. Check the settings in your software and see if there is an option to adjust the loop start time or buffer size. Upgrade your hardware: If your device is older or has limited processing power, it may struggle to process loops quickly. Consider upgrading your device or using a dedicated loop pedal or controller to help reduce the delay. Use a pre-recorded loop: If you don't want to record the loop in real-time, you can try using a pre-recorded loop instead. This can help eliminate the delay and allow you to play the loop instantly. Practice timing: With some practice, you can learn to time your loop so that the delay is less noticeable. Try starting the loop a few beats before you need it to start and see if this helps. PartyCityFeedback Survey Quote Link to comment Share on other sites More sharing options...
