eduardocanton Posted February 14, 2023 Share Posted February 14, 2023 I have noticed a problem with the 4CH configuration. My amplifier in the Loop uses line level. If I want to use the 4CH method it would mean that the signals that come out of the stomp in the Loop of the amplifier are the OUTPUT and RETURN signals. I can set the output signal in the configuration as "line", but if I change the Return signal to "line" it also affects the Send, and the send should be "instrument". Any idea how to solve the problem? thanks Quote Link to comment Share on other sites More sharing options...
rd2rk Posted February 14, 2023 Share Posted February 14, 2023 The FX Loop Block has SEND and RETURN Level parameters. Use them. OR you can use separate S/R Blocks set as required. A waste of Blocks and your second loop, but if method 1 above is too difficult for you, there ya go! Quote Link to comment Share on other sites More sharing options...
