darrylhebert Posted February 16, 2023 Share Posted February 16, 2023 Hey all! When my Helix expression pedal is physically past the 50% mark, it won't stay there and just falls all the way down to 100% (full volume). The physical pedal just slides when past the half way mark, no resistance, it won't stay in one spot. Is there an easy adjustment to fix this issue? Quote Link to comment Share on other sites More sharing options...
theElevators Posted February 16, 2023 Share Posted February 16, 2023 Tighten the pedal with the supplied Hex key. When making adjustments, do it in small increments. If that doesn't help, then maybe you've loosened the pedal to such an extent, that you will need to open up your Helix and attach the nut to the bolt. 3 Quote Link to comment Share on other sites More sharing options...
darrylhebert Posted February 16, 2023 Author Share Posted February 16, 2023 thx! I'll try that Quote Link to comment Share on other sites More sharing options...
darrylhebert Posted February 17, 2023 Author Share Posted February 17, 2023 thx! all fixed. Didn't even notice there was an adjustment hole there. Cheers! Quote Link to comment Share on other sites More sharing options...
