mtumi Posted February 25, 2023 Share Posted February 25, 2023 The video shows the issue. micro.clock > MC6 > HX stomp > RC-10r = double time micro.clock > MC6 > RC-10r (remove HX stomp) and the tempo is set correctly Thoughts? Michael Quote Link to comment Share on other sites More sharing options...
mtumi Posted February 25, 2023 Author Share Posted February 25, 2023 Found a post that led me to a resolution, although i don't follow logically why turning off Tx MIDI Clock should fix it. unless it is two different sets of clock going out - one thru from the chain and another generated by the HX stomp itself. I guess that would make sense. In any event turning off Tx MIDI Clock seems to have fixed it Quote Link to comment Share on other sites More sharing options...
phil_m Posted February 25, 2023 Share Posted February 25, 2023 On 2/25/2023 at 10:57 AM, mtumi said: Found a post that led me to a resolution, although i don't follow logically why turning off Tx MIDI Clock should fix it. unless it is two different sets of clock going out - one thru from the chain and another generated by the HX stomp itself. I guess that would make sense. In any event turning off Tx MIDI Clock seems to have fixed it Yes, you wouldn't want to have the Stomp sending its own MIDI clock signal if it's already passing the signal from the other pedal through. Quote Link to comment Share on other sites More sharing options...
