Connecting Variax 700 to a Pod HD500X
I have purchased a used VAriax 700and connected it ia the Variax cable to my PodHD500X.
Eventhough I selected VAriax as input, there is no sound to hear.
Whe playing through PS, all is OK.
Can someone help me how to get the Variax700  connected to the Pod HD500X?
Appreciate any support in this matter.
Kijang
Check if the variax neutrik connector VDI has damaged bent pins, in which case the connection via VDI can't work, and replacement of that connector would be needed.
Also check the neutrik connector VDI of the POD.
Years ago I bought my Variax 700 online at a bargain price but when it arrived I soon realized that its VDI was damaged, so I replaced the neutrik connector and since then it has worked perfectly connected by VDI to my HD500X.
Here is the pic of a perfect neutrik connector:
F4262410-01?pgw=1
Note that the variax cable could be also the culprit, if you have an ethernet cable that you are sure works fine, try using that to connect the variax to the pod. If the connection works then it is obvious that the problem is in the variax cable.
_______________________________________________________________________________________________________________________________________________________________________
All about POD HD500/X
help and useful tips
