ssiowi Posted April 14, 2023 Share Posted April 14, 2023 Here's the Wet/Dry/Wet dream for my Helix: Guitar to Helix: Guitar In Helix Left/Mono 1/4" Out to Amp (Dry) (Catalyst 100) Helix Left/Mono XLR Out to pedalboard power amp (via DIY XLR-to-1/4" T/S cable w/ Helix set for instrument level) (Wet) Helix Right XLR Out to pedalboard power amp (via DIY XLR-to 1/4" T/S cable w/ Helix set for instrument level) (Wet) L & R pedalboard power amps to DIY 1x12" FRFR cabinets (passive with Celestion F12-X200 speakers) Curious about: the viability of the XLR to 1/4" paths for the L & R Wet paths running those inputs to the pedalboard power amps at Instrument vs. Line level out of the Helix Okay y'all; bring the opinions, experiences, advice, etc. Thanks and cheers, Dave - Helix, Variax, Catalyst Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 15, 2023 Share Posted April 15, 2023 Guitar>Helix Guitar In>anything you want before the Catalyst and WET paths>Send 1 to Catalyst (DRY) Dry Thru 100%> Stereo FX at mix = 100% (optional - mix % to taste)>1/4" or XLR Outs L/R. If you want stuff before the Cat but NOT on the wet paths, split Path A before the FX you want only in the Cat, add the SEND with DRY THRU at -120db, then at the MIX Block set Path A Level to -120db and Path B (your WET FX) to 0db. I'm not sure that setting Path A at the Mix Block to -120db is essential since the DRY THRU at the SEND is already -120db, but there's possibly a level thing due to PAN LAW (google it) considerations. Experiment! Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 15, 2023 Share Posted April 15, 2023 He's asking for advice. The way I described gives him the choice of running the SEND/DRY (at INST Level) into the front of his amp or at Line Level using a Helix Amp/Preamp into his Amp's FX Return. The XLRs with his wet FX go to his L/R pedalboard Power amps and speakers. There're other ways to wire this, I just covered the first two that came to mind. Quote Link to comment Share on other sites More sharing options...
