Moving Setting to new Board
As long as your disabled unit is able to connect to POD HD500X Edit, or you already have a backup of your dream preset, you’ll be OK. Use the editor with your disabled unit connected to save backups of (export) whatever presets and setlists you want to transfer. Then close the editor program, disconnect your old unit, connect your new unit, and launch the the editor again to import the stuff you saved.
Before doing that you should check to see whether the firmware of the new device needs updating, and do it if so.
