jamosher Posted May 13, 2023 Share Posted May 13, 2023 Hi, I’m new to the Helix family and stereo routing in general. Not sure how complicated this is to route, but I just acquired a Tech 21 DI-2112 that has outputs for the deep and drive sections that I’d like to process separately and routed with a dry output that runs into my bass cab and wet output for my modulation/delays/verbs/etc ran through an frfr. Any visual diagram or explanation would be greatly appreciated! Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 13, 2023 Share Posted May 13, 2023 Answer depends on your specific goals and gear. Helps to know which Helix family device you're using? Using Stereo FX to stereo FRFR? Deep/drive on separate channels? Separate processing for each? Quote Link to comment Share on other sites More sharing options...
jamosher Posted May 13, 2023 Author Share Posted May 13, 2023 Hi, I’m using a single PA speaker for my wet signal routed in mono and my dry signal will be routed to a bass cab powered by a power amp. The Helix LT is the brain in this situation. My idea is to have all of my effects routed to a wet signal for the sake clarity and so that my low end doesn’t fall flat when I engage any modulation. Quote Link to comment Share on other sites More sharing options...
jamosher Posted May 13, 2023 Author Share Posted May 13, 2023 Forgot to mention, but the deep and drive sections will be in separate channels so I can process them differently. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 13, 2023 Share Posted May 13, 2023 EZ PZ. Demo preset attached. Take the DRIVE/DEEP OUTs from the Sans Amp to the L/R Inputs of the LT. Take the 1/4" L/Mono Out (Path 1A, no FX) from the LT to the Bass amp. Take the XLR L/Mono Out (Path 1B with FX) from the LT to the FRFR. jamosher.hlx Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 13, 2023 Share Posted May 13, 2023 On 5/13/2023 at 10:18 AM, jamosher said: Forgot to mention, but the deep and drive sections will be in separate channels so I can process them differently. New Demo preset attached. Decide which input you want to use for each Sansamp channel, Paths 1A and 2A are for whatever is in the LEFT INPUT. Paths 1B and 2B are for whatever is in the RIGHT INPUT. jamosher2.hlx Quote Link to comment Share on other sites More sharing options...
jamosher Posted May 13, 2023 Author Share Posted May 13, 2023 Thank you so much!!! Quote Link to comment Share on other sites More sharing options...
jamosher Posted May 13, 2023 Author Share Posted May 13, 2023 Haven’t had the chance to use the preset yet, but can I share effects between the two channels? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 14, 2023 Share Posted May 14, 2023 On 5/13/2023 at 1:36 PM, jamosher said: Haven’t had the chance to use the preset yet, but can I share effects between the two channels? Anything placed before the split on Path 1 will be on both channels. 1 Quote Link to comment Share on other sites More sharing options...
