HX Stomp footswitch assign question.
Aged_Cheddar
OK, so just a little back story.
I'm typically using a LT as my main gigging rig, but I wanted something smaller for a backup/bedroom practice rig, I'd briefly used my guitar players Stomp (which led to the LT purchase), so I just got my own yesterday.
Now, my LT can accommodate my entire "rig" on just one preset, however the Stomp can't, so I've basically set up two presets....Clean/Modulation and Dirty/Modulation, inside of each preset the 3 main stomp buttons are perfect to call up whatever effect I need at the moment.
So, I bought a 2 button footswitch with the intent to use FS4 for Tap/Tune and FS5 to toggle between the two presets, the tap/tune was no problem, but setting a FS to toggle between two specific presets eludes me, perhaps it's not possible unless you use midi?
Thoughts? Work arounds?
Thanks!
I just found the solution!
While I'm in "preset 1" load up command center and tell FS5 to load "preset 2", save the preset.
Then, when in "preset 2" load up command center and tell FS5 to load "preset 1", save the preset.
Now, whenever I hit FS5 it toggles between my two presets!
When you switch to a different preset, that preset has to have a similar FS to switch back or to another.
IOW - the new preset doesn't know how it got there or where to go next.
If what you want to do is use a single FS to go to EITHER preset A or preset B, like, short press = A, long press = B then no, that only works with snapshots.
You posted while I was typing. Problem solved!
