Brianchurilla Posted May 29, 2023 Share Posted May 29, 2023 I want to have two outputs from my Pod Go. #1 line level to FOH (like the main out). This output would NOT be affected by the volume control knob on the top of the unit. #2 would also be line level to a Headrush 112 and would use the volume control knob on the top of the unit. The point of this is to have 2 signals, one to FOH and the other to the HR and I would be able to adjust my volume of the Headrush remotely. Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 30, 2023 Share Posted May 30, 2023 Try this setup: #1 to FOH. Use the Amp Out jack. In Global Settings set this to Line level and set the Amp Out Src to Main Out. This is an unbalanced output so depending on the venue you may need to use an external DI box to feed FOH. #2 to HR. Use the Main Out jack. In Global Settings set this to Line level. 1 Quote Link to comment Share on other sites More sharing options...
