badwolfboyzz Posted June 7, 2023 Share Posted June 7, 2023 Hi, just got a Problem to connect my Helix to the JVM 410 HJS according to the 4 Cable Method: In this connection, i only want to use the except section of the helix, no amp/cabinet simulations Even when connecting properly it doesn't work; i don't understand because there is a proper FX loop in/out on the top Any hints/advice to help me ? Thank you all, bets regards Wolf Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 7, 2023 Share Posted June 7, 2023 On 6/7/2023 at 5:42 AM, badwolfboyzz said: …. Even when connecting properly it doesn't work…. Please describe exactly how your cabling is connected, from guitar to speaker/cab/monitor. Even with correct cabling your Helix preset needs to be properly configured. To use only the Helix FX (no amp/cab modeling) your preset needs to include an active FX Loop block (or individual Send/Return blocks) in addition to no amp/cab blocks. 1 Quote Link to comment Share on other sites More sharing options...
badwolfboyzz Posted June 8, 2023 Author Share Posted June 8, 2023 Hi Silverhead, thank you for that proposal! This is quite different from the normal 4 C setting and i agree to your explanation. I will try the next days, thank you very much ! Quote Link to comment Share on other sites More sharing options...
