andrewcel Posted June 20, 2023 Share Posted June 20, 2023 Hello apologies for this as my knowledge is pretty limited - I want to use my Pod Go for bass to go through a PA for gigs and rehearsal rooms - what process do I have to go through to make this happen...I'm really not too sure what I'm doing with it :| Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 20, 2023 Share Posted June 20, 2023 Connect the Pod Go's Main Outputs to the PA/mixer inputs. Use only the L/MONO output unless you want to send a stereo signal. I presume this will replace any bass amp that you are using and that you will be monitoring yourself through the PA. If you need a separate amp/monitor for yourself connect the Pod Go Amp Out to that. Check the Pod Go manual page that shows the rear panel hardware jacks and read the descriptions for Main Out and Amp Out. Quote Link to comment Share on other sites More sharing options...
