addersb Posted June 27, 2023 Share Posted June 27, 2023 After two years working perfectly the alternate tunings are now playing a mix of standard and alternate tunings notes on each string. It is all coming through the amplifier and occurs even if I create a new custom tuning. I have tried a factory reset as described in the manual but this didn't work. Any ideas what may have gone wrong? Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 27, 2023 Share Posted June 27, 2023 First, make sure that you are not just hearing the physical standard tuning from the string vibrations. They can be heard easily unless your amp is really loud and are often interpreted as a Variax problem, which they are not. Make a recording if you can, or use closed headphones. The acoustic vibrations will not be recorded and will be inhibited by the headphones. After eliminating that possibility, another possibility is that your firmware may have become corrupted. Try using Workbench HD to back up your current banks/models (bundle), then run Line 6 Monkey to reinstall the Variax firmware, then use Workbench HD again to restore your bundle. Quote Link to comment Share on other sites More sharing options...
