Dual Mono HX effects
Felixhelix75
Hi.
I’m sorry if this sounds like a dumb question, but if I want to run two Fender hot Rod amps in dual mono (both through the front as I don’t use amp gain circuit), is it as simple as running output left and right to each amp? I saw a video of running wet dry and was advised to use a phase inverter. I just want two amp either side of the stage doing the same thing. Can I just plug both In using both outputs? Thanks
