blujosh Posted July 31, 2023 Share Posted July 31, 2023 sorry if this is a noob question, but... i'm wondering which Helix/HX can do parallel amp + effects chains where the entire "Right" from in to out and entire "Left" signal from in to out are discrete? to be more specific, i'm hoping to process my electric guitar through two different signal chains: 1) clean guitar amp (amp + cab) w/ reverb 2) polyphonic octave down > dirty bass amp (amp + cab) [for simulated bass sounds i have an active splitter pedal that i can place before whichever Helix/HX to send my unprocessed guitar signal into the two inputs, if needed. Quote Link to comment Share on other sites More sharing options...
craiganderton Posted July 31, 2023 Share Posted July 31, 2023 Parallel, discrete signal chains are part of Helix's DNA. HX Stomp can do two totally independent parallel chains (split the input, then pan the output mixer so one channel is full right, the other full left). Helix Floor and Rack can do 4 parallel, independent chains. I've even figured out how to do 4, 6, and 8-channel surround with Helix floor. (There's info on how to do this in the latest version of my Helix eBook, although I don't think most users are interested in using it for surround.) The simulated bass sound application you mention works really well for me. I recommend adding two EQs before the Poly block to help keep the higher notes from reaching it. I use a 10-band graphic EQ as the first EQ to cut out everything except the low notes, followed by a parametric EQ that boosts the low note levels. As a result, you hear only the guitar’s lower strings play an octave lower. I also follow the Pitch block with a compressor to help bring up the sustain, which makes the low frequencies sound more like a bass. It's a cool effect if you're a solo performer, and want a pseudo-bass line behind your playing. 1 1 Quote Link to comment Share on other sites More sharing options...
