Command Center Snapshots not going back to "original state"
BmanTaz
Hello Helixers!
I newly threaded into the Command Center to make my Control Unit  (Helix Rack with Control Unit) more suited to my own needs.
However I stumbled upon a little problem that i hope some of you wise-bois can help me with.
Before i used the Command Center to layout my Control Unit to be this layout (PRESET x4 on top 2x snapshots and 2x stomp in the buttom and a L6 Mission Exp pedal)  All my snapshots would go back to original state after i switch between them (i have a Wah on EXP and a Pitch Shifter on the 2nd stomp) But after i used the Command Center to layout my CU, it seems that they simply wont go back to their normal state, lets say that i press on LEAD Snapshot and use the Pitch Shifter, it will still stay ON even if i made it in the settings that it would automatically go back. Any help to fix this would be greatly appreciated
Best Regards
Bjarke Andersen
