haule Posted September 1, 2023 Share Posted September 1, 2023 HI, is it normal that my variax acoustic nylon 300 has, a very low outout volume compared to electric guitar and the upper 3 strings volume is lower that thicker strings. Is there anything I can do to get the volume same for all strings? Is there replacement parts available anywhere? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted September 2, 2023 Share Posted September 2, 2023 Try using the original Workbench application. Check the Lin6 downloads page for that, and the computer OS compatibility. May need a secondary back compatible OS for that. Quote Link to comment Share on other sites More sharing options...
haule Posted September 4, 2023 Author Share Posted September 4, 2023 Hi, nylon 300 don't have connection for workbech, it has only normal cable output which can be used to power nylon 300. Thank you anyway. I'm thinking sending it to nearest service center. I bought this guitar as it was, and didn't pay enough attention to it then. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted September 5, 2023 Share Posted September 5, 2023 Right, no WB for the nylon, forgot that. Haven't serviced a nylon in a while. Service center would be good. An older product like that, I would expect a solder point or two to go intermittent, or a connector not seating in all the way. And they can check and/or adjust the set-up as needed. Quote Link to comment Share on other sites More sharing options...
