Struong57 Posted September 16, 2023 Share Posted September 16, 2023 Greetings, I have had my Helix floorboard for about a year now and have a setlist of 84 songs, which I have sorted in alphabetical order by song name. I constantly save this setlist to my MacBook just so I don't lose everything in case of a glitch. The question I have is, is there a way for me to print/save a list of all of my 84 presets from this setlist so I can quickly glance at that list and see if I already have a preset for a particular song? I would like to be able to look at this list without having to turn on my Helix. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
silverhead Posted September 16, 2023 Share Posted September 16, 2023 There's no direct way to get a text file that lists only the preset names. But there is a way to get them in a format you can work with. In HX Edit under the File menu select Extract Files From Backup... This will open a dialog where you can select the setlist(s) whose presets you want. Of course you may need to Create Backup... first. The Preset files will be exported to a folder, one folder per setlist. In that folder will be the set of preset files listed in order of preset#. The format of each filename is 'Presetxxx-<presetname>.hlx'. That in itself may be all you need. If you want to tidy it up you're into PC or MAC folder manipulations. Quote Link to comment Share on other sites More sharing options...
Struong57 Posted September 18, 2023 Author Share Posted September 18, 2023 Thank you, @silverhead. Your suggestion accomplishes what I needed. Quote Link to comment Share on other sites More sharing options...
