harryjone Posted September 18 Share Posted September 18 I have a question about expression pedals. I am finding a used Mission Engineering SP-1 pedal, will it work with my Line 6 HX effects? I am confused because I see they have Mission Engineering SP-1 L6H. What's the difference between the two, if any? And will SP-1 work regardless? Thank you Quote Link to comment Share on other sites More sharing options...
Schmalle Posted September 19 Share Posted September 19 The difference is in the wiring. Without soldering iron you can cut the green cable(s) inside and use a dual mono to stereo 1/4" cable. With a soldering iron you can mod the SP1 to become a L6H in two minutes: Desolder the cables coming from the switch from the output jack 2. Output jack 2 is not needed. Desolder the green cable coming from the pot from the output jack 1 and solder the red cable from the switch there instead. Solder the black cable coming from the switch alongside the black cable. The output jack now looks like this: the two black cables (from the pot and the switch) on the sleeve the red pot cable on the tip the red switch cable on the ring 1 Quote Link to comment Share on other sites More sharing options...
