Catalyst 60 Manual Mode w/Foot Pedal to Activate Boost
RFMando
RE:
Catalyst 60 in Manual Mode w/Foot Pedal to Activate Boost
Loving the Catalyst 60 - want to use manual mode not preset and use the foot pedal to activate the boost, anyone figure out "how" to do this yet?  thx!
Plug in the FS.
Turn on the amp.
Press the MANUAL button.
Press FS 2.
If that doesn't toggle the BOOST, then:
Connect to your computer with a USB cable.
DL and install the Catalyst Edit App - there are versions for PC, MAC and iOS.
Open the app.
Click the SETTINGS icon - the gear looking thingy on the right end of the Menu Bar at the top.
In the pop-up, at the lower right corner is a FS icon - FS2.
In the pop-up select BOOST BYPASS.
Press FS 2.
Thank You!  Sounds like I'll need the app then to edit.  When I plug in the footswitch and power up and press manual the effect on right controls effect on/off and the channel is the other option but when I click that it changes it from manual to channel B.  If I'm following I can set the effect switch to activate the boost instead of the effect option on the amp?  I'll d/l the Catalyst Edit app and report back, thank you again!
Yes, I really like how I have the manual settings dialed in and also want to leave the effect on.  Just would be nice when I hit channel to activate the boost on the "manual" channel I'm on.  Maybe, if all else I can dial B in for boost like you recommend!  Thx again :-)
