HX Stomp Snapshot problem
maxiblues
Hi all
I'm newbie HX stomp user. When I try to use Snapshots I can't to modified and save single presets of effects.
If I change for example Gain of one pedal Distorsion or A Delay level I find the same value on all 3 Snapshots.
I can only turn it singles effects ON/OFF but not internal setting effects o settings Amp/ preamp Ecc.
Someone can help me?
Many Thanks
Cheers
MaX
Make sure you assign the desired parameter(s) to the Snapshot controller. From the manual:
To adjust a parameter AND have it automatically update per snapshot, press and turn the knob. Snapshots remember the values of up to 64 effects parameters. The parameter’s value appears white, indicating a controller’s assigned to it—in this case, the Snapshots controller:
Also I suggest you read the Snapshots chapter in the manual. There’s a Global Setting called Snapshot Edits that you need to understand.
