flavaham555 Posted September 28, 2023 Share Posted September 28, 2023 Hey there, not sure if this is in the right place but it's the only place that it would let me create a post for some reason. Anyhow, I'm using snapshots now. I have it set up to have 4 snapshots at the top and 4 stomps at the bottom. Can I change which stomps are available for each snapshot? Example - for my clean tone I'd like to have a chorus pedal that I can switch on and off. For my crunch tone I'd like to be able to toggle my reverb on and off. I only have four buttons available and three that I absolutely need are a distortion pedal, delay and tremelo. So I need to figure out how the switch the other one between chorus and reverb for different snapshots. Hopefully this makes sense. Not even sure if this is possible. Thanks! Quote Link to comment Share on other sites More sharing options...
PaulTBaker Posted September 29, 2023 Share Posted September 29, 2023 I don't think you can do that. however, you could use command center and have your the FS's change per snapshot. I am not sure if you can assign a block to a FS in command center, but you could create two snapshots that use your chorus and reverb, then depending on which snapshot you are in, you could assign a FS your chorus or reverb snapshot. One drawback is I think you have to be in stomp mode for the command center assignments to work. I don't know if they work with Snap?/Stomp mode. You could easily test it. If not, just put your 4 snapshots assigned to the top 4 FS's and do that in each snapshot.... That would give you close to the same thing. just a thought. Quote Link to comment Share on other sites More sharing options...
