jewbacca331 Posted October 23, 2023 Share Posted October 23, 2023 Hi, everyone. I hope this finds you all well. I am new to the Helix, but so far it is incredible. So my problem is as follows: I play a lot of Phish and I want to use the "Once" function in the 6 button looper like Trey does where I can tap it to the rhythm of the song continuously. However, it is impossible as the Once button is in the second row. I would like to swap the REV/FWD switch with the Once switch. Is that possible? Am I just missing the ability to long press and swap button assignments on the board? Thanks so much! Quote Link to comment Share on other sites More sharing options...
silverhead Posted October 24, 2023 Share Posted October 24, 2023 You can’t reassign the Looper buttons within the Looper display. You can, however, assign a footswitch in Stomp mode to control the Looper functions, including Play Once. See the manual section on Command Center. There is a subsection describing Looper controls. Quote Link to comment Share on other sites More sharing options...
