Stomp Routing Question
Aged_Cheddar
OK, so I have a technical routing question...
I'm a bassist, and my main gigging rig is a Helix LT, I have it setup so the signal exiting through the XLR out (to FOH) has a amp & cab sim, then I have another signal exiting the ¼ out that has everything EXCEPT the amp & cab, that signal goes to my stage amp (when I use one)...I LOVE this setup because it allows me the option to use my actual rig too...there's just "something" about feeling that bass behind me on big stages that I just can't get enough of.
So, I have a need to use my HX Stomp for a few shows that have what I would be calling...less than ideal stage real estate at the front of the stage, but have room for a small combo amp in the back.
So I'm curios about using the Stomp for this group of shows, but I do use the FX loop in mono [L], so can I split my path and send path [A] with an amp/cab sim to my main output (L) then off to FOH...and then send path B without the amp/cab out of return [R] to my stage amp?
I feel like this would work, but my amp is in the gear trailer so I have no way to “real world” test this...my fear is that since I AM using the FX loop even though just mono in [L], that it will still interfere with using the RET [R] as an output the way I'm thinking.
Thoughts?
Could This Work?
Better Suggestions?
Thanks in Advance!!
On 11/3/2023 at 8:41 PM, Aged_Cheddar said:
So I'm curios about taking the Stomp for this group of shows, but I do use the FX loop in mono [L], so can I split my path and send path [A] with an amp/cab sim to my main output (L) then off to FOH...and then send path B without the amp/cab out of return [R] to my stage amp?
The attached example preset shows how.
Use a TRS>Dual Mono (INSERT CABLE) in the SEND jack.
FX Loop L (TIP) is before the split.
L MONO OUT goes to FOH with the cab.
Send R (RING) Outputs the same signal minus cab to your stage amp.
The "DRY THRU" parameter of the SEND R block set to -120db prevents the Path B signal from going to FOH.
Aged_cheddar.hlx
