mwrigor Posted November 4, 2023 Share Posted November 4, 2023 I just want to check what everyone thinks about this. I use my Stomp live and feed the mainL/R to FoH and the SendL/R to my personal monitor. See image. What has me baffled is the routing assignment, because I'm sure I hear a difference when the sendL is in the path (as compared to removing it). Can't figure out why, I would assume the SendL really does the same thing as the SendL/R. Is it me or is there an explanation to what I am hearing? Quote Link to comment Share on other sites More sharing options...
Schmalle Posted November 4, 2023 Share Posted November 4, 2023 The Send output jack has three pins: Tip, ring, sleeve. SendL sends a mono mixed signal via the Send output's tip, no signal on the ring. SendL/R sends a stereo signal via the Send output using tip for L and ring for R. If you connect to your monitor with a TS cable you get the reverb mixed to mono with SendL and the left reverb channel with SendL/R. If you use mono reverb there should be no difference btw. If you use a TRS cable into a balanced input of the monitor it'll sound weird with the SendL/R unless you use Type Mono and Pan L100. Quote Link to comment Share on other sites More sharing options...
mwrigor Posted November 4, 2023 Author Share Posted November 4, 2023 Aaah ok. I see. Cheers! Quote Link to comment Share on other sites More sharing options...
